Mk4 Vag -Com atrastie errori...
Laurent
Post by Laurent » 24.05.2009, 21:51
Kāds nepateiktu ko šie nozīmē? Vai kur varetu atrast informaaciju, ko viņi dara, vai nedara?
Address 01 -------------------------------------------------------
Controller: 038 906 012 M
Component: 1,9l R4 EDC 0000SG 2813
Coding: 00002
Shop #: WSC 01317
5 Faults Found:
19560 - Valve for Intake Manifold Flap (N239): Short to Plus
P3104 - 35-10 - - - Intermittent
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-10 - - - Intermittent
17948 - Vehicle Speed Signal: Signal too High
P1540 - 35-10 - - - Intermittent
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-00 - -
17964 - Charge Pressure Control: Negative Deviation
P1556 - 35-10 - - - Intermittent
Readiness: N/A
Runa iet par sencīša MK4!
Mk4 GTI TDI Exclusiv
Alpine & Zeus
Re: Mk4 Vag -Com atrastie errori...
Post by Marchs » 24.05.2009, 22:56
Laurent, vai šitas ir spams? Tak liec normālā sadaļā, kur pienākas!
buu
Post by buu » 25.05.2009, 00:01
shis te liekas, ka man arii bija:
tas ir no paarspiediena iespeejams... Jaskataas vai tas VNT mehanisms straadaa turbiinai. Iesaku aizbraukt liidz INC, lai paskataas kaa straadaa
Laurent
Post by Laurent » 25.05.2009, 13:45
Marchs wrote:Laurent, vai šitas ir spams? Tak liec normālā sadaļā, kur pienākas!
Labi, pierunāji... :p
Alpine & Zeus
