[Golf 6] Check deadlock.
Mentalists
VW: Golf 6, 1.6 TDI, 2012 gads.
Post by Mentalists » 14.06.2018, 10:30
Sveiki,
Man ir VW Golf 6, 1.6TDI Hečbeks 2012 gada.
Lieta tāda ir, kad izslēdzu dzinēju, man parādās sistēmas paziņojums Check deadlock, ko tas varētu nozīmēt? Google atradu visādas jēlības, viena ir, lai izslēdz dzinēju kad durvis ir atvērtas, otra ka tas ir vienkārši paziņojums lai neaizmirstu aizslēgt durvis, vai jums ir idejas?
Līdzīgi kā bildē, tikai man nav rakstīts Owner's manual!
https://prnt.sc/juscjc
Deimons
VW: Golf MkIV TDi 4mo
Re: [Golf 6] Check deadlock.
Post by Deimons » 14.06.2018, 10:42
Thanks eurotrashed... I finally just found a reason for it on a UK site... Apparently it's a new 'feature' to warn you that the doors will be deadlocked when you lock them... In case you have kids in the car, you lock the car to go do something (probably pay for fuel, or do a few rounds of the pokies I'm guessing) and something happens to the car, the kids won't be able to exit the car because it's deadlocked and the unlock button inside on the drivers door won't open the doors when it's deadlocked.
Apparently most cars with a deadlock you have to press the key twice to activate the deadlock, whereas with VW you only press it once, hence VW feel the need to warn you of the risk of deadlocks... using a message that makes you think something's wrong with the car... Go figure... It apparently is referred to in the Owner's Manual as 'Safelock', however I can't verify this because the Dealer still has my car trying to bring it up to delivery standard (Note to self, don't ever let dealers fit standard accessories ever again).
