zemāk video ir parādīts , pielaižot dzinēju , eļļas lampiņa nomirgo 3x reizes un apstājas (oranža) ko tas nozīmē ? un vēl , kas ir tas trujstūris aplī kurš ir spidometra lauciņā? Domāju kad VW īpašnieki zinās:) Ceru uz atsaucibu. paldies:)
Auto : VW Golf Mk4 2000.g. 1.4i 16v .
http://www.youtube.com/watch?v=YGkBbqI5 ... -9mXpMsQfg
Golf Mk4 eļļas indikators .
Re: Golf Mk4 eļļas indikators .
VW Golf Mk4 traction warning light - indicates that the vehicle does not have the correct traction for the surface of road, proceed with care. If light remains on use the VAG COM diagnostic kit to diagnose the problem, your vehicle is not performing as it should.
VW Golf Mk4 engine oil pressure warning light - check your engine oil levels and top up as required. If the engine oil pressure light remains on it could indicate that the oil level sensor in your VW Golf Mk4 is faulty and needs to be replaced.
1 - VW Golf Mk4 trailer turn signals indicator light
2 - VW Golf Mk4 cruise control system warning light
3 - VW Golf Mk4 operate foot brake warning light
4 - VW Golf Mk4 rear fog light warning light
5 - VW Golf Mk4 glow plugs warning light for diesel vehicles
6 - VW Golf Mk4 turn signal indicators
7 - VW Golf Mk4 coolant temperature/level warning light
8 - VW Golf Mk4 brake wear monitor warning light
9 - VW Golf Mk4 main beam indicator light
10 - VW Golf Mk4 low fuel warning light
11 - VW Golf Mk4 traction control system warning light
12 - VW Golf Mk4 anti lock brake system warning light (ABS light)
13 - VW Golf Mk4 electronic immobilizer warning light
14 - VW Golf Mk4 brake system warning light
15 - VW Golf Mk4 alternator warning light
16 - VW Golf Mk4 SRS airbag warning light
17 - VW Golf Mk4 engine management warning light
18 - VW Golf Mk4 engine oil/pressure warning light
19 - VW Golf Mk4 door or tailgate open warning light
20 - VW Golf Mk4 screen wash level warning light
21 - VW Golf Mk4 exhaust emissions warning light
22 - VW Golf Mk4 seatbelt warning light
Iesaku iepazīt savu auto! Eļļas līmeni esi skatījies?
