- VW: Golf 3, 1.8 Mono
- Has thanked: 221 times
- Been thanked: 103 times
Post
by ibumetiins » 20.08.2019, 18:20
msh wrote: ↑20.08.2019, 18:04
Kopš kura laika kaut kādam 1.8 mono var būt 100 zs?
Vienīgais man zināmais VAG mono kam ir 100 zs ir 2.0 iekš C4 A100 - iekš B4 2.0 mono ir 90 zs, tas pats ar visādiem 1.8 mono.
Es taču teicu "Rakstīju viņam ka zem 100 hp,". Kurš saka ka 1.8 mono var būt 100 zirgi?
Un tas tiešām ir kaut kas tāds par ko stresot - 90 vai 100 zirgi? Šā vai tā neiet
Post
by ibumetiins » 20.08.2019, 18:21
fokume wrote: ↑20.08.2019, 18:12
Bet kāda starpība cik tur zirgi, tur jau sen jābūt 60hp ar check engine, kurš jau 2003.gada tika aizlimets ar melno izolācijas lentu.
Man nav nemaz tāda check engine lampa
Post
by msh » 20.08.2019, 18:23
ibumetiins wrote: ↑20.08.2019, 18:20
Šā vai tā neiet
Vajag uzlikt VEMS un turbīnu...
Post
by fckns » 20.08.2019, 18:25
1.9TDI no Pasāta b4 un būs lapi.
msh wrote: ↑16.06.2024, 04:55
- Has thanked: 153 times
- Been thanked: 265 times
Post
by Nordik » 20.08.2019, 18:56
Klusuma festivals
Post
by fckns » 20.08.2019, 19:26
Nepiesārņosim dabu - lietosim retro lietas.
- Has thanked: 234 times
- Been thanked: 563 times
Post
by fokume » 20.08.2019, 22:01
vai ari dpf off miskastu ipasnieki, lai ievada izputeju salonaa, piedarbina un padara pasauli labaku un panem kapaa liidzi savu izpederasito motoru, kuram dpf off palidzeja labak elpot
Post
by arniks8 » 20.08.2019, 22:09
suuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuknja motors bestest
mdz wrote: ↑14.06.2021, 16:34
Post
by Nordik » 20.08.2019, 22:19
Kas tieši viņam labāks?
Post
by fokume » 20.08.2019, 22:24
Var uzlikt bosio forsunki un lielais plunzeris un jonix chip
Post
by msh » 20.08.2019, 23:20
Nordik wrote: ↑20.08.2019, 22:19
Nav aprīkots ar dārgām sprauslām un dilstošām sadalenēm.
Post
fokume wrote: ↑20.08.2019, 22:01
Savam mk4 jau esi šo modu izveicis?
Post
by arniks8 » 20.08.2019, 23:22
msh wrote: ↑20.08.2019, 23:20
Bet ir aprīkots ar pašiznīcinošu vibrāciju
Post
by fokume » 20.08.2019, 23:25
tas golfs lec uz pus apgriezienu, nedumo un vieta ir ari katalizators
nee nopietni, paskatoties uz dumojosiem c6, mans musars ir topzustand
Post
by arniks8 » 20.08.2019, 23:28
TUK, TUK
Kas tur?
Vārstiem pizdā
- 20190820_204819.jpg (217.11 KiB) Viewed 950 times
